configure cfm domain association destination-mac-type
configure cfm domain domain-name association association_name destination-mac-type [unicast | multicast]
Description
Allows you to choose the destination MAC type for sending CFM PDUs for an MA.
Syntax Description
domain_name
Enter the domain associated with the MA you are configuring.
association_name
IEEE 802.1ag or ITU-T Y.1731 association name.
unicast
CFM PDUs are sent to the unicast MAC address configured in static remote MEP creation.
multicast
CFM PDUs are sent to the standard multicast destination address.
Default
Multicast.
Usage Guidelines
Use this command to change the MAC type on a previously configured MA. If multicast is selected, CFM PDUs are sent to the standard multicast destination. If unicast is selected, CFM PDUs are sent to the unicast MAC address configured in static remote MEP creation.
Use the show cfm command to verify your configuration.
Platform Availability
